Thermostat or Temp Sensor?
Old Apr 25, 2008 | 11:05 AM
gordo79's Avatar
Default Thermostat or Temp Sensor?
02 A4 3.0L Quattro, 89K. At first the issue was an engine coolant gauge that would stop working intermittently. A few days ago it stopped working all together, now have a CEL. When the car is in city traffic with little air movement I can actually see the outside temp gauge increase 5 to 10 degrees, it then returns to normal at highway speed. After driving home last night from work (30 to 40 minutes of highway driving) I could place my hand on the radiator. However, I was getting heat in the cabin. This leads me to belive that my thermostat is not opening up and allowing the coolant to ciculate into the radiator, hence the overheating at city speeds. Could this however be an issue related to why my engine coolant gauge stopped working, like maybe a faulty temperature sensor?
Any help would be greatly appricated.
Gordo.
Old Apr 26, 2008 | 12:55 PM
AudiTech616's Avatar
Default RE: Thermostat or Temp Sensor?
if you scan the car then there should be a fault for your temp sensor if it's bad. Other then that it sounds like a thermostat.
Old Apr 26, 2008 | 08:16 PM
audiprotein's Avatar
https://www.audiforums.com/m_808550/tm.htm
It might be the coolant temp sensor, if it is, you have a chance for the free replacement by an Audi.
Old Apr 26, 2008 | 08:28 PM
auditech79's Avatar
If the thermostat was stuck open coolant would always circulate throught the radiator and the engine probably wouldn't reach operating temp. If it were stuck closed, no coolant would circulate throught the radiator and it would overheat something fierce. If the radiator feels hot and your getting hot air from the cabin vents, its most likely a CTS failure.
Mckayiva4
Dec 10, 2010 06:39 PM
toboater
Oct 26, 2010 12:15 PM
fullcollapse318
Apr 28, 2010 10:09 PM
nikovision
Jul 15, 2008 09:19 PM
Milky
Nov 3, 2005 10:26 AM
