Traction Control light
Old Sep 10, 2008 | 06:26 PM
Hintzer's Avatar
Default Traction Control light
I have an 2003 Audi A4 1.8T. I changed the air filter on my car to a spectre air filter. i took out the old air filter and air filter box but i didnt touch the massair flow sensor and the check engine light came on. i pulled the codes and got the codes cleared and the light went off but came back on when i turned the car off and then turned it back on later. does anyone know what is wrong and how i can fix that? also when i changed that the traction control light came on. does anyone know why that came on and what i can do to keep it off?
Old Sep 11, 2008 | 07:38 AM
ThreePointOhhh's Avatar
you have to tell us what codes you have then we can begin to help you
Old Sep 11, 2008 | 03:00 PM
Pablo_Ottawa's Avatar
Did you remember to reattach the small plastic hose that also connects to the airbox??? I got a CEL due to that error
Old Sep 11, 2008 | 05:59 PM
Hintzer's Avatar
so would i need to put the airbox back in cauz i took it out cauz the filter wouldnt fit in that air box?
Old Sep 14, 2008 | 10:38 PM
Hintzer's Avatar
i am getting a P0102 code
Old Sep 15, 2008 | 01:23 AM
auditech79's Avatar
P0102
Mass or Volume Air Flow Circ Low Input
This is indicating that you messed something up with the mass air flow sensor, and this is the cause of your traction control light as well. Check the wiring to the sensor and make sure you plugged it in correctly. If everything looks ok then you might have damaged the MAF sensor.
bentley3282
Oct 26, 2019 07:59 AM
fyreous
Feb 18, 2010 05:11 PM
tooka
Dec 10, 2008 06:33 PM
germantech
Sep 13, 2007 12:42 AM
stefanwieckowski
Dec 16, 2006 10:15 PM
