Originally Posted by pa4ul
(Post 1383935)
i would say its the motor. but had your window shown any signs of going up and down slowly. It also could be the regulator if u hear alot of binding inside the door. Heres the diy to get an idea of what you are looking at?
DIY: B6 A4 Window Regulator & Motor Replacement |
Main Problem?
Hi,
Just curious, what was the faulty component at the end? I have the same issue on my car too. And my window is stuck down! :-( Everything works except for the mirrors and driver side window. I'm assuming it's a power issue as none of the switches are lit as well. Any help is appreciated :-) |
need help guys. on my audi i am able to roll down all windows from master switch except the diver window. the other switches on each door dont work. i already replaced the master switch? any thoughts? thanks
my driverside window isn't working
hi,
i have an 02 audi a4 and the problem is that my driver side window isn't working. it happened today itself when i used the switch to get my driver side window up. the window was to close properly when suddenly i heard an unusual sound when it reach on top. it made a "tac" sound. i tried to get the window down but it was blocked. the window motor seem good. can u please help asap. thx:) |
You could always try the window switch http://switchdoctor.net 30 day return policy.
Hey Pa4ul, I saw you mentioned something about the light on the window switches going out, my switch for my drivers side front window stopped working and also my mirror adjuster stopped working but all of the other switches work on the the driver side front door. My light has also went out. Do you possibly know what could have caused that? I would really appreciate that help!
also need help
Hello I also need help. -03' A4 B6 3.0v- windows go down but can't control them off the driver door only on each door single handedly. Can hear the motors run but no movement when switches are applied. any thoughts ? Thank you very much
All of my car doors are not working I but before they were. All of a sudden they stopped working and I don't hear and clicking noise
