turbo timer questions
Old Aug 5, 2008 | 04:44 AM
20percent's Avatar
Default turbo timer questions
i have a 2004 a4 1.8t and i am looking to get a turbo timer for it (it is bone stock)
i am looking for the most simple timer availible
i want to mount the display (if there is one) in the glove box where it cant be seen
i dont want an estimated air fuel mixture or anything else
what do you guys recomend
thanks
Old Aug 5, 2008 | 10:58 PM
hardenthefckup's Avatar
why is your interest in a turbo timer for a stock car?? are you aware that the turbo has coolant and oil lines hooked up to it?? well if your not, then.... FYI, your turbo is cooled down with coolant. if you still want 1 then the apexi is my choice and thats what i have and dont worry about af ratios because that gauge is not made for that nor is accurate, but the timer works great. also you wont be able to arm your alarm and lock doors till shuts off because you have to hook up a relay in the factory alarm system, but when you stop you can just turn the key off then put parking break on, that way the timer cant come on.
Old Aug 6, 2008 | 03:06 AM
20percent's Avatar
so there isnt a turbo timer out there that would not interfere with my security system?
i just want to be able to leave my car when i get somewhere instead of waiting for the turbo to cool down
Old Aug 7, 2008 | 02:07 AM
20percent's Avatar
any more advice?
has someone done this before?
Old Aug 7, 2008 | 01:15 PM
widgget's Avatar
it has to disable the security system since the car would not run with it enabled.
not the ideal way to do it but it's better then waiting every time you stop the car in my opinion.
o6A4Audi
B7 Models
Jun 5, 2015 03:01 PM
Prizmatik
Jul 13, 2008 01:14 AM
votblindub
Mar 30, 2007 12:05 PM
ayabaloo
Jun 23, 2006 05:39 AM
johnnyspade
Jul 28, 2005 06:15 PM
