turbo timer questions
i have a 2004 a4 1.8t and i am looking to get a turbo timer for it (it is bone stock)
i am looking for the most simple timer availible
i want to mount the display (if there is one) in the glove box where it cant be seen
i dont want an estimated air fuel mixture or anything else
what do you guys recomend
thanks
thanks
why is your interest in a turbo timer for a stock car?? are you aware that the turbo has coolant and oil lines hooked up to it?? well if your not, then.... FYI, your turbo is cooled down with coolant. if you still want 1 then the apexi is my choice and thats what i have and dont worry about af ratios because that gauge is not made for that nor is accurate, but the timer works great. also you wont be able to arm your alarm and lock doors till shuts off because you have to hook up a relay in the factory alarm system, but when you stop you can just turn the key off then put parking break on, that way the timer cant come on.
ayabaloo
Jun 23, 2006 05:39 AM
