AudiForums.com
-   B6 Models (https://www.audiforums.com/forum/b6-models-70/)
-   -   Vacuum leak? (https://www.audiforums.com/forum/b6-models-70/vacuum-leak-93735/)
mjr2008 Mar 3, 2008 06:44 PM
Vacuum leak?
Please bear with me. I haven't worked on a car since my 1994 Jeep Wrangler where I was the professional "light holder" for my dad. I have a 2003 A4 1.8T Quattro. A CEL went on a few days ago and I started having idle fluctuation. After reading several posts, etc., I decided it was likely an O2 or MAF issue or vacuum hose issue. Today, I popped the hood and heard a pretty noticeable hissing sound, located it's source (see below pic for general area) and think I found the hissing hose and tightened it after sliding it up a bit. I'm resetting the code to see if that's the fix. My only question is can someone tell me if the below pic is in the general vicinity of a vacuum hose issue? It's embarrassing to admit, but I'm clueless on this engine. Thanks.
[IMG]local://upfiles/50046/A0853F9EECAF451E9960601BED7D665C.jpg[/IMG]
cincyTT Mar 3, 2008 07:13 PM
RE: Vacuum leak?
There is a good amount of vac lines coming off the manifold there and some go in that direction. You also have the pcv system back there also that is known to leak.
