AudiForums.com
-   B6 Models (https://www.audiforums.com/forum/b6-models-70/)
-   -   wheel offset for B6 A4 question? (https://www.audiforums.com/forum/b6-models-70/wheel-offset-b6-a4-question-116886/)
octechgeek Oct 27, 2008 08:27 AM
Will these specs work for a B6 A4 and how flush will they come to the fender or is it too agrresive and will stick out a bit?
Front- 30 offset, 8" wide
Rear- 27 offset, 9" wide
ThreePointOhhh Oct 27, 2008 08:52 AM
sounds too agressive. that 27 et in the back would most likely rub. 30 in the front as well. are you lowered? that increases the chances of rubbing. i dont think you should go lower than 32. you also have to make sure you can clear your brakes.
RLGarage Nov 15, 2008 03:52 PM
Can you tell me the stock offset on a set of OEM 17's? I am looking for another set of wheels and don't know what will fit. Car is standard height...Avant
ThreePointOhhh Nov 16, 2008 05:18 PM
stock 17s are et45
