2005 Leaking under Tran
Old Mar 16, 2009 | 05:45 AM
emostop's Avatar
Default 2005 Leaking under Tran
About 3 days ago, driving as normal, then went to go back into 1st, and no go. 2nd , 3rd etc were giving trouble to get the gear. After a few go's, finally got it, but its very sticky to get it into gear now, if at all.Checked under, and found a clear liquid ( prob like brake fluid, but had not hoist so couldnt get a good look ) leaking around the clutch, and sump area.I was thinking possibly the slave cylinder ?? but the pedal aint sticking etc .any advice ?
Old Mar 16, 2009 | 10:01 AM
dmfan016's Avatar
if it was brakes the color would have been red,
clear fluid could just be water and u coulda have had a hard itme with the gears if it was cold outside
did u touch the fluid? was it greeasy? if it was then it could have been gear oil (im assuming its a manual tranny)
Old Mar 16, 2009 | 11:26 AM
emostop's Avatar
Yea, the fluid is a little greasy, and clear, but gear usually have a stronger odour ?? it is the 1.9TDI , does it have a seperate reservoir for the clutch fluid ? Because the brake fluid seems clear in the reservoir. it also just seemed more viscous than water. thanks again !
Old Mar 16, 2009 | 06:43 PM
dmfan016's Avatar
ohhhhh i didn't think it was a diesel sorry man i have no idea with deisel engnies but i have always had red brake fluid i thought there was a standard color for fluids,
blue - windhsield
red - brakes
green- coolant
orange - tranny fluid
Old Mar 16, 2009 | 06:45 PM
dmfan016's Avatar
i woul check gear oil seeing as your trouble is stemming from a transmission issue rather then brakes unless you have noticed your brakes acting up recently
Oh Boy!!
Jul 7, 2011 03:47 PM
ALLBLKALLROAD
May 30, 2008 08:47 PM
kopez03
Feb 9, 2007 12:01 AM
bontyal
Feb 26, 2006 03:17 PM
AudiCoog
Aug 16, 2005 03:55 PM
