2005 Leaking under Tran
About 3 days ago, driving as normal, then went to go back into 1st, and no go. 2nd , 3rd etc were giving trouble to get the gear. After a few go's, finally got it, but its very sticky to get it into gear now, if at all.Checked under, and found a clear liquid ( prob like brake fluid, but had not hoist so couldnt get a good look ) leaking around the clutch, and sump area.I was thinking possibly the slave cylinder ?? but the pedal aint sticking etc .any advice ?
if it was brakes the color would have been red,
clear fluid could just be water and u coulda have had a hard itme with the gears if it was cold outside
did u touch the fluid? was it greeasy? if it was then it could have been gear oil (im assuming its a manual tranny)
Yea, the fluid is a little greasy, and clear, but gear usually have a stronger odour ?? it is the 1.9TDI , does it have a seperate reservoir for the clutch fluid ? Because the brake fluid seems clear in the reservoir. it also just seemed more viscous than water. thanks again !
ohhhhh i didn't think it was a diesel sorry man i have no idea with deisel engnies but i have always had red brake fluid i thought there was a standard color for fluids,
blue - windhsield
red - brakes
green- coolant
orange - tranny fluid
blue - windhsield
red - brakes
green- coolant
