Idle hunts & whissle @ idle.
Old 01-02-2010, 12:55 AM
Mean buzzen half dozen 08 A4's Avatar
Cool Idle hunts & whissle @ idle.
Could not see the flucuation w/the tach but could definately hear it & feel it.
Also had a CEL on.
This was going on for a week ,then got an appointment @ a Audi dealer,but at a couple days before we took it in,there was a loud high pitch squeeling ,sorta sounded like the front brakes squeeling,but it was not the brakes.
My wife took her car in because the idle was hunting/surging @ 850 RPM or so,also a CEL & loud whistle
Anyways,the dealer rep knew exactly what it was & said it would take about an 1/2 hr to fix it.
The part they changed was a PCV,,they called it a power control valve,,,is that the diverter/blow off valve?
Thanks
Car runs great again.
Old 01-02-2010, 02:35 PM
TTT,,,anyone???
Old 01-04-2010, 11:46 PM
Cool
TTT,,anyone know?
Thanks
Old 01-05-2010, 12:15 PM
eMacPaul's Avatar
I've only seen PCV previously to mean Positive Crankcase Ventilation. So I don't know whether those would be the same thing.
Old 01-05-2010, 12:52 PM
Midniteoyl's Avatar
However, are you asking if yours could be the same thing? I'm confused...
Old 01-05-2010, 08:02 PM
The dealer called it a power control valve,my question is,,,,,,,,,,,,,,is the power control valve a diverter valve A.K.A. blow off valve that recirculates back into the intake system?
Is this the part that fails when running higher boost pressure than stock boost levels?..... I think the factory has a platic diaphram?
The upgrade is a forge diverter valve. Like this http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
or http://cgi.ebay.com/ebaymotors/Forge...Q5fAccessories
Thanks
Old 01-05-2010, 10:59 PM
Midniteoyl's Avatar
Your gonna haveta get clarification.. as far as I know, there is no power control valve.
Old 01-05-2010, 11:36 PM
aetius's Avatar
When my PCV valve was defective I had a little oil being pushed out around the filler cap. Also my performance was a bit off. There was no strange noises coming from the engine though. And yes, PCV is Positive Crankcase Ventilation. Your mechanic may have meant
the diverter valve?
http://forums.vwvortex.com/zerothread?id=3366758
goody
02-14-2011 12:05 PM
justinclarke
11-25-2010 04:03 PM
00A41.8Quattro
09-28-2006 05:45 AM
drkenan
12-10-2005 03:08 AM
Quick Reply: Idle hunts & whissle @ idle.
