Bad smell in engine
Old May 13, 2014 | 01:23 PM
kwekusam's Avatar
Default Bad smell in engine
Hi, I own 2 2004 model of audi A4 and i notice a bad smell when i accelerate hard. I had the valve gasket changed, changed the plugs and engine oil, but still smell the bad scent. Can someone pls offer me ideas on what the cause could be?
Old May 14, 2014 | 08:34 AM
rhodes991's Avatar
Is the smell in the engine bay or out the tailpipe? if it is the tailpipe try filling up at a different gas station. If it is a burning oil smell check for additional leaks. If the PCV goes bad it can cause oil to blow back. If you haven't replaced that it might be a good idea.
Old May 14, 2014 | 11:19 AM
mhoward's Avatar
what does it smell like?
Old May 16, 2014 | 10:22 PM
imaudi5000's Avatar
any fluids leaking under the car when parked? possible radiator/coolant leak? my old car had a crack in the radiator and hose and spewed green coolant all over the hot engine and it smoked and smelled bad.
shelpster
Apr 20, 2011 09:50 PM
twinturbosixer
May 8, 2009 03:28 AM
19_A4_99
May 31, 2007 01:35 PM
mypreludeisred
Oct 13, 2006 03:37 PM
gspreeman
Nov 6, 2005 02:42 AM
