Chip
Old Oct 14, 2010 | 12:42 AM
asb09's Avatar
Default Chip
Okay so I am thinking about getting either a REVO chip or an APR chip but I have heard it is smart to upgrade the dv. So what i was wondering was how necessary is it to do this? Also if i were wanting to run stage 2 after I got one of those chips, would it be possible to do so with just an intake and a downpipe? or would i need to upgrade the cat or the test pipe or both?
Old Oct 15, 2010 | 11:11 AM
eMacPaul's Avatar
What year is your car? Newer cars have better DVs. I've been chipped for almost 20k with the stock DV.
Old Oct 15, 2010 | 01:27 PM
asb09's Avatar
Its an 07 a4 2.0t with 44k on it
Old Oct 17, 2010 | 06:06 PM
2wdBlazer's Avatar
Read my sticky up top. Seems like I have to answer this alot. You will need a DV eventually as with a chip it will probably fail. It could fail gradually and if you don't have a Boost gauge you may not even notice it. The newer piston driven DV does not fail like the ones with a diaphram.
Old Oct 18, 2010 | 11:55 PM
makav3li's Avatar
All stage 2 does is delete the cat code that kicked out with a test pipe or HFC.
Old Oct 21, 2010 | 12:58 PM
2wdBlazer's Avatar
Stage 2 deletes the code and has different mapping to take advantage of the new exhaust flow. Call the company if you like but it is a diifernt map for sure. I ran with a stage 1 car and downpipe for a few days and then went stage 2. I could even tell the difference although most was my downpipe.
Stage 2 is a minimum on these cars. Once you have it you kick yourself for going so long without it.
mitch's sline
B7 Models
Oct 4, 2008 07:57 PM
s4noob
9
Jun 24, 2008 02:41 PM
ricehead
Nov 4, 2005 10:59 AM
