Help cheep VagCom cable broke my Audi
[solved] Help cheep VagCom cable broke my Audi
Was a dead battery after all.
I was testing out the VCDS-light software and while the software was trying to pull information my Audi started to go crazy. Some warning lights went on and the emergency break light started flashing.
When I try to start the car it beeps a few times and the headlights flash for for a minute and then stop. If I try to turn the ignition some winding noise is heard behind the DIS but does not start.
The DIS is also blank only the time, trip and warning lights show.
I scanned for errors and only got this.
I checked the battery voltage and it is ~12.5v
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 08: Auto HVAC
Controller: 8E0 820 043 AM
Component: A4 Klimaautomat 2731
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00532 - Supply Voltage B+
53-00 - Supply Voltage Too Low
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
