Possible water in relays
Hey all so, I have a 2007 A4 2.0T. The cover where the relays are is cracked and I didn’t notice before it was too late. I noticed when my fan would come on after the car was shut off, then my engine light and epc light came on. These are the error codes I’m getting, can anyone guide me in what I can do and what I may be looking at as far a cost or whatever. I’m pretty green so may just have to take it to a shop but if it’s just replacing relays then idk. P0659
Raw code: 0659 ECU: Engine control unit Status: Pending OBDII: Actuator supply voltage - circuit high ============2============== P0444 Raw code: 0444 ECU: Engine control unit Status: Pending OBDII: Evaporative emission (EVAP) canister purge valve - open circuit Audi: Evaporative Emission Control System Purge Control Valve Circuit Open ============3============== P0243 Raw code: 0243 ECU: Engine control unit Status: Pending OBDII: Turbocharger (TC) wastegate regulating valve A - circuit malfunction Audi: Turbocharger Wastegate Solenoid 1 ============4============== P2400 Raw code: 2400 ECU: Engine control unit Status: Pending OBDII: Evaporative emission (EVAP) leak detection pump, control - open circuit ============5============== P0030 Raw code: 0030 ECU: Engine control unit Status: Pending OBDII: Heated oxygen sensor (HO2S) 1, bank 1, heater control - circuit malfunction Audi: HO2S Heater Control Circuit Bank 1 Sensor 1 ============6============== P0037 Raw code: 0037 ECU: Engine control unit Status: Pending OBDII: Heated oxygen sensor (HO2S) 2, bank 1, heater control - circuit low Audi: HO2S Heater Circuit Low Voltage Bank 1 Sensor 2 ============7============== P2295 Raw code: 2295 ECU: Engine control unit Status: Pending OBDII: Fuel pressure regulator 2 - circuit low ============8============== P0135 Raw code: 0135 ECU: Engine control unit Status: Pending OBDII: Heated oxygen sensor (HO2S) 1, bank 1, heater control - circuit malfunction Audi: HO2S Heater Performance Bank 1 Sensor 1 ============9============== P0130 Raw code: 0130 ECU: Engine control unit Status: Pending OBDII: Heated oxygen sensor (HO2S) 1, bank 1 - circuit malfunction Audi: HO2S Circuit Closed Loop (CL) Performance Bank 1 Sensor 1 |
I have an 07 A8, and the ECU is fairly easy to access, so I would disconnect the battery cables, disconnect the ECU, open it and dry it if it's wet. A hair dryer and just having it indoor will dry it.
Interested to hear what you did. |
