Radiator Fan Not Working? No Code.
Hi all, my radiator fan is not working causing my car to overheat... As long as I'm cruising down the highway I'm good... But if I hit a drive thru or heavy stand still traffic, my engine just... "eats" my coolant/water replacement at this point because spending $20 every day in coolant... Nah bro. It's summer here in GA, water is a better solution right now.
The codes I'm throwing are P2015, P2008 and P0299. P0299 is the newest code, the other two have existed for years, I've just been too lazy to replace the intake manifold control. I did blow a radio fuse when I jumped my car after it sat for 4 months, but replaced that. I have checked the fuses in my driver side door panel and they all seem to be good. What gives? |
I believe their is a temp sensor that tells the fans when to kick on. that may be your issue.
