Slipring for MFSW
Hi,
Wich slipring i need for a MFSW. Now i have a 4E0953541 but understood that i need a 4E0953541B. Can i also use the 4E0953541A? Thnx |
Nobody??:confused:
It looks like there are no members on this forum that can awnser my question. :(
I'm going to go on a limb and say not many people understood your Question. MFSW and random part numbers does not offer much clarity.
Originally Posted by 2wdBlazer
(Post 1250170)
Maybe somebody already experienced this with changing there steeringwheel by a Multifuncitioneel Steeringwheel. Like i told is that the partnumbers for a Slipring are 4E0953541 but the letter on the end tells wich functions it support. for example: Normal steeringwheel with only horn and airbag = 4E0953541 Multifunctional steeringwheel with paddles = 4E0953541 A Multifunctional steeringwheel without paddles = 4E0953541 B NOW! I have a Multifunctional wheel mounted but do not have the right slipring and the dealer tells me i need the B version. My question is if somebody knows if i can also use the A version even with a wheel with no paddles...... |
Originally Posted by Haddock
(Post 1250330)
How hard can it be.....
Maybe somebody already experienced this with changing there steeringwheel by a Multifuncitioneel Steeringwheel. Like i told is that the partnumbers for a Slipring are 4E0953541 but the letter on the end tells wich functions it support. for example: Normal steeringwheel with only horn and airbag = 4E0953541 Multifunctional steeringwheel with paddles = 4E0953541 A Multifunctional steeringwheel without paddles = 4E0953541 B NOW! I have a Multifunctional wheel mounted but do not have the right slipring and the dealer tells me i need the B version. My question is if somebody knows if i can also use the A version even with a wheel with no paddles...... I would say use what you have stock or have onhand first. If it does not work order the right part. That's what I would do. |
I did a little looking and I saw that some B6 guys were using the A,B,C and D series. As long as the pins in the plug are the same it should work and be thae same size. Good luck.
Thanks for your awnsers guys,
I agree that the best solution is to use the B version like my dealer told, but i can not find the B version on internet, several A versions are for sale |
Go to http://www.genuinevwaudiparts.com, search for "4E0953541B". It's $301.
Originally Posted by eMacPaul
(Post 1250925)
New i can get them everywhere and that is why i want to know if i can use the A version. The A version is for sale on ebay for 57 euro(79 Dollar) |
