Synchronize remote key
Old Aug 23, 2009 | 09:44 AM
capman's Avatar
Default Synchronize remote key
Ive just bought myself an Audi 2.0T avant quattro 2005 and got a key thats not synchronized.
Ive been reading the manual for it but it doesnt seem to work, the manual says:
- Push the remote manouverbutton for unlock.
- Stick the key in the ignition and turn it on.
- Turn the ignition off and pull the key out.
- Press the unlock on the key and then the lock.
That should be it but it doesnt work, the key itself works im just using the key to unlock and start the engine etc.
Any tips?
Been trying to search on the forums but havent got any clue's on this model.
Old Aug 23, 2009 | 05:44 PM
clemsongt's Avatar
Does the red light blink when you push a button? If it doesn't (and maybe even if it does) then you probably have a dead battery.
Old Aug 23, 2009 | 05:59 PM
copper07's Avatar
I would change the batteries. Also when you change the batteries press the buttons on the remote with the batteries removed. I have heard that by doing this will allow the remote to sync with the car.
Old Aug 24, 2009 | 02:17 AM
capman's Avatar
Yeah, the red light on the remote key is flashing when im pressing any button on it, but it could be a bad battery so im gona try to exchange it and try to resync the key.
Thing is that ive found multiple solutions on how to synchronize the key and i was hoping that someone had the right instructions.
Since the manual that came with the car doesnt always tell the truth in theese cases.
Old Aug 24, 2009 | 11:34 AM
clemsongt's Avatar
The process in the manual has worked for me. When I've disconnected the car's battery I've had to resync the key. The process in the manual works every time.
Old Feb 13, 2010 | 11:58 PM
Amy80's Avatar
Post
Hi
Could anybody help me how to sync my new key? I only had one key for my Audi a6, but I lost is!!! I had to order 2 from the service. A got the keys but the car wont start!!! There is any way I can sync the key at home, or I have to tow it to the service and they will do it for me?
Thanks
Amy
Old Feb 16, 2010 | 01:29 AM
Quattros's Avatar
dealer would do it for you if you bought the keys from them or at least they should.
Old Feb 16, 2010 | 04:19 PM
Dougie Fresh's Avatar
It's probably simpler than this but it worked for me.
I took a working key, inserted it in the ignition and turned it so the radio came on.
I inserted the non-working key in the door, turned it to lock, pressed the lock button, repeated a few times. Did the same with unlocking the door and pressing the unlock button. I am not sure how many times I did each. I was just trying something I'd read on another site.
I took the key out of the door and ignition and the keyfob that was not working started working.
This was for a '07 A4.
Old Feb 17, 2010 | 10:04 PM
Audi Tek's Avatar
Tech Certified
that is generally the sync procedure.
for B7's... Sometimes it didn't work for me and i had to do it with an audi scan tool.
Amy80, The starting of the car using a key.... that key need to be adapted to the car it was cut for by VIN via network Germany at your local dealership
AudiGirl92
B7 Models
Aug 31, 2013 08:28 AM
MartinCieslak1
Dec 11, 2009 02:30 PM
krshrk
B8 Models
Sep 18, 2009 07:08 PM
whaaamx5
Nov 20, 2007 02:00 PM
///A4
May 8, 2006 06:51 PM
