Turbo Cut off Valve
Old Jul 3, 2009 | 08:05 PM
MikeyCO421's Avatar
Default Turbo Cut off Valve
I have an 06 A4 2.0T and recently noticed my check engine light was on and that my turbo wasn't kicking in. I took it to a local shop and they said it came back reading that it needed a turbo cutoff valve - which they also called a booster pressure sensor (I'm thinking it's either the same thing or the sensor is part of the valve part??). Anyone have any idea as to how hard these are to replace if I were to do it on my own?
Old Jul 4, 2009 | 10:30 AM
clemsongt's Avatar
They are not hard at all. The hardest part is getting ramps or jack stands in the right place.
You should buy the part 06H 145 710 D. There are several websites around the net that will have one. I got mine from genuineaudiparts.com (try searching under VW...for some reason they don't have it listed under Audi).
Crawl under the car and find the diverter valve with an electrical cable clipped to it and mounted with three 5 mm torx screws and pull it out. There are some DIY's that might help on this site or other forums like Audizine.
07titanium
B7 Models
Oct 25, 2011 08:11 PM
idriveb5
Oct 24, 2011 09:16 AM
nycrca77
Mar 29, 2008 02:49 PM
cukilo
Jun 8, 2005 01:28 PM
FtMyersAudiFreak
May 25, 2005 11:35 PM
