Window Issues
Old 10-16-2017, 10:02 AM
Paulciceroaudi's Avatar
Default Window Issues
I have had intermittent issues with my windows not going up from the driver's door control module. They all work fine when I put the key in the door on the outside and turn to the left/right. Does this mean the door switch went? Regulator? motor? Thanks!
Old 10-16-2017, 01:28 PM
rhodes991's Avatar
I have read that the contacts on the switches can get dirty and cause issues. If the switch goes bad I believe you have to swap out the whole unit (expensive) as the switches cannot be replaced individually.
Old 10-16-2017, 02:25 PM
thanks, I will see about cleaning the switches
Old 10-16-2017, 04:07 PM
KingWulfgar's Avatar
Yeah, it's likely the main window switch. Replacement isn't that bad. I bought the $42 VEMO one from ECS and it's fine. Feels about the same and the light color matches close enough. Nobody but me would know it was a replacement. Pretty easy to do too--especially if you've removed your door panels before.
Mr.Gerb1k
09-28-2013 11:00 PM
h4x0r
12-31-2011 12:20 PM
02A4kid
12-27-2011 12:59 PM
toyolla86
01-02-2007 09:03 PM
Quick Reply: Window Issues
