upgrade list
Was wondering what you all thought of my list. any do's or don'ts that you see.
Custom exhaust with test pipe, and single Borla muffler 3'' exhaust all the way out to dual exhaust
APR stage 1 chip
New diverter vale
BSH pcv revamp
new cam follower-kmd
either JHM or KMD Short shifter kit
turbo timer and boost gauge
power pulley upgrade-neuspeed
Of course upgraded headlights/tail lights
APR stage 1 chip
New diverter vale
BSH pcv revamp
DO
Read my stickey up top (maybe you have as most of this is in there)
Custom exhaust with test pipe, and single Borla muffler 3'' exhaust all the way out to dual exhaust (Test pipe and muffler only will save you cash as stock pipe is plenty on our turbo's)
APR stage 1 chip (Stage 2 since you are getting the test pipe, more power same price)
New diverter valve (Stock D-Valve)
BSH pcv revamp (Awesome)
new cam follower-kmd (OEM is the best fit and cheaper. I have heard of issues with KMB beacuse of the size difference, don't chance it when OEM will be good for at least 30k)
either JHM or KMD Short shifter kit (sounds pretty cool)
boost gauge (good move to make sure you have no leaks)
DONT's
turbo timer (No need on these cars, waste of money)
power pulley upgrade-neuspeed (minimal if any power gain for the money)
Sounds like you are headed in the right direction.
DONT's
APR stage 1 chip
New diverter vale
BSH pcv revamp
APR stage 1 chip
New diverter vale
BSH pcv revamp
skip the cam follower and turbo timer.
Sounds good to me. BSH, Forge and 42DD all make great slide in taps. Gauges are all personal preference but Eurojet makes an affordable Electronic unit. Electronic ones still use a needle but use a very short vaccume source to a sender. Super accurate and never stick.
Ok so are there two kinds of diverter valves? Kinda confused. There are the ones like the forge splitter that you hook up to the two hoses and then there are ones that are electronic like this?
Audi B7 A4 Quattro 2.0T > Engine > Intake > Diverter Valve > ES#263879 Upgraded Piston Diverter Valve, Electronic - 06H145710D
Im new to turbos so i dont really know much. Thanks guys
