VAG COM question NEED HELP!!
Old Feb 9, 2008 | 04:12 PM
PhukenA's Avatar
Default VAG COM question NEED HELP!!
I got this fault code from a VAG test...can anyone help explain this for me? i.e. what exactly is this problem? What is the cause of it? Is this a fuel pump? My car seems to run fine, maybe a little lag on the low end, but I dont want to run into further problems.
VAG-COM Version: Release 704.1
Data version: 20071016
Friday,08,February,2008,17:54:44:59577
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Mileage: 77220km/47982miles
Address 01: Engine Labels: 06F-907-115-AXX.LBL
Part No SW: 8E0 910 115 M HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0060
Coding: 0104010A02070120
Shop #: WSC 22162
1 Fault Found:
012555 - Low Pressure Fuel regulation: Fuel Pressure Outside
Specification
P310B - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 2
Mileage: 75467 km
Time Indication: 0
Freeze Frame:
RPM: 5697 /min
Load: 100.0 %
Speed: 102.0 km/h
Temperature: 84.0°C
Temperature: 25.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.716 V[/align]
Old Jul 15, 2010 | 02:57 PM
apquigly's Avatar
Default DId yoiu get an answer? I have same fault at same mileage
Hi,
Did you resolve this fault on your car? I'm running into hte same fault and a shop said it could be wearing of the cams which run the mechanical fuel pump. Seems strange at 47k changing oil every 5k with synth.
Thanks,.
Andy
Old Jul 16, 2010 | 07:57 AM
makav3li's Avatar
Sounds like ur cam follower, i just posted on apquigly's thread above, read that 1 for more information. And there is alot of information on that problem around cuz its considered "common" and it should be changed every 30k miles or so.
Old Jul 22, 2010 | 04:20 AM
Quattros's Avatar
low pressure sensor.
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
