Problem with initial throttle tip in 2011 A4 B8
Old Dec 19, 2012 | 11:15 AM
rjsracer's Avatar
Default Problem with initial throttle tip in 2011 A4 B8
I own 2011 a4 quattro Prem+ auto 2Twith about 21,000 and it appears during initial warm up and intermittently, that there is a response lag upon my initial throttle tip in. More notice in regular (vs sport) setting of transmission.
Is this a none issue with the B8?
I have used techron additive to fuel to see if it might be related to fuel. Only use Shell or Chevron prem fuel.
Also, looking at modifying my exhaust this spring to a Stasis or APR. Any recommendation on a dual vs single exhaust system. I plan on taking it autocrossing and enjoying it on long drives, so I need to strike a balance between decibels and performance. Any insight on set up ?
Old Dec 30, 2012 | 12:11 PM
rjsracer's Avatar
Does anyone have a similar problem?
Old Jan 15, 2013 | 10:03 AM
Built2crash's Avatar
There might be a TSB for this..... ECU re-flash maybe. I didn't think it effected 2011's though.
Old Jan 15, 2013 | 10:08 AM
Ben1415's Avatar
It's an a4 designed as an economy car hence why they have s4's and rs4's. it's not a sports car just bc it's an Audi. Get a good tune or if you wanna drive fast (somewhat at least) then just put it in sports mode.
Old Jan 16, 2013 | 09:24 AM
rjsracer's Avatar
Thanks for your responses. Just to be clear, I understand the B8 A4 will not have a throttle response of a car with a light weight flywheel or with gearing designed for acceleration. Instead, I was referring to no response on the initial throttle tip in, which causes abrupt acceleration when moving from a standing still, especially in winter driving. This happens whether car is warmed up or not.
Any thoughts?
marioslazouras
Sep 30, 2013 04:29 AM
patrykb
Nov 1, 2011 02:28 PM
roaddog49
Aug 7, 2011 01:08 PM
brightside06
Sep 6, 2007 10:31 PM
bbowman011
Jul 13, 2007 07:48 AM
