URGENT-Audi A4 B8 2008 Lambda Sensor short to ground(P1115) (P0671,P0672,P0673,P0674)
Hello,
Recently my car had broken down due to not starting, my mechanic had taken a look at the car and had found that the battery had been putting out 10V instead of 12V. When i picked up the car and drove off, shortly after my DPF light had come on!! i immediately drove back to the mechanics where he had a quick look at it, i noticed he unplugged the Lambda sensor to check something and then plugged it back in, he then proceeded to scan the car with his scanner and found a lamda sensor fault (not sure if unplugging it caused an issue). anyway, i drove it back home to see if a forced regen would sort the problem out and it didn't, i then borrowed VCDS of a friend of mine which showed several errors with the DPF sensor so i replaced it and problem was solved for that but the lambda senor fault was still there. i had the mechanic replace the lambda sensor and the fault still wont disappear, when i clear the code it comes back straight away (£165 down the drain). i have checked all fuses boot, driver side, passenger side and bonnet and they seem to be fine. i done a visual inspection of wires but can not see anything that has melted, iv also noticed after a little bit of driving around i also get another fault code P0671, P0672, P0673 and P0674 Glow Plug Circuit electrical fault, not sure if they are related in any way. Faults P1115 - Lamda Sensor (B1 S1) Short to ground P0671 - Cylinder 1 Glow Plug Circuit - Electrical Fault P0672 - Cylinder 1 Glow Plug Circuit - Electrical Fault P0673 - Cylinder 1 Glow Plug Circuit - Electrical Fault P0674 - Cylinder 1 Glow Plug Circuit - Electrical Fault Any help would be appreciated. |
Tuesday,05,July,2016,19:39:21:12273
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 15.7.4.1 (x64) Data version: 20160216 Ross-Tech: Home VIN: WAUZZZ8K99A065490 License Plate: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8K (8T0) Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 72 77 VIN: WAUZZZ8K99A065490 Mileage: 94930km-58986miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CAGC) Labels: 03L-906-022-CAG.clb Part No SW: 03L 906 022 HW: 03L 906 022 B Component: R4 2,0L EDC H01 3177 Revision: --H01--- Coding: 0104002C18072018 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_ECM20TDI03L906022 A01005 ROD: EV_ECM20TDI03L906022.rod VCID: 62CD94C87560402E08-8036 4 Faults Found: 5110 - Oxygen (Lambda) Sensor Heating: B1 S1 P1115 00 [175] - Short to Ground MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 94928 km Date: 2008.04.08 Time: 08:25:15 4984 - Cylinder 1 Glow Plug Circuit (Q10) P0671 00 [101] - Electrical Fault Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 94928 km Date: 2008.04.08 Time: 19:36:15 4986 - Cylinder 3 Glow Plug Circuit (Q12) P0673 00 [101] - Electrical Fault Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 94928 km Date: 2008.04.08 Time: 19:36:15 4987 - Cylinder 4 Glow Plug Circuit (Q13) P0674 00 [101] - Electrical Fault Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 94928 km Date: 2008.04.08 Time: 19:36:15 Readiness: 1 1 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb Part No SW: 8K0 907 379 AA HW: 8K0 907 379 AA Component: ESP8 front H04 0060 Revision: -------- Serial number: -------------- Coding: 160500 Shop #: WSC 06325 000 00000 VCID: 78F9D6A0CBFCBAFE46-802C No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 C HW: 8K0 907 064 C Component: BCM2 1.1 H70 0134 Revision: 00002001 Coding: 031100 Shop #: WSC 06325 000 00000 VCID: 30692E80630CA2BECE-8064 Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D Component: FBSAUDIB8 IDG H37 0060 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: ELVAUDIB8 H35 0039 4 Faults Found: 00955 - Key 1 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 3 Fault Frequency: 17 Reset counter: 234 Mileage: 75956 km Time Indication: 0 Date: 2014.06.26 Time: 18:07:52 00956 - Key 2 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 238 Mileage: 94846 km Time Indication: 0 Date: 2008.04.04 Time: 20:02:07 01330 - Central Control Module for Central Convenience (J393) 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 241 Mileage: 94899 km Time Indication: 0 Date: 2008.04.06 Time: 08:59:20 02811 - Control Module for Electronic Steering Column Lock (J764) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 243 Mileage: 94916 km Time Indication: 0 Date: 2008.04.07 Time: 02:59:19 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8T2 820 043 S HW: 8T2 820 043 S Component: KLIMA 3 ZONEN H06 0140 Revision: D0000000 Serial number: 0124.06.080694 Coding: 34040000 Shop #: WSC 06325 000 00000 VCID: 428D7448DDA0202E28-8016 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 C HW: 8K0 907 063 C Component: BCM1 1.0 H22 0253 Revision: 04022001 Serial number: 00000000176384 Coding: 260050914034AF000001000000001D0D001D03080001014100 0000 Shop #: WSC 06325 000 00000 VCID: 2F6B2DFC7E32BD46D7-807A Subsystem 1 - Part No SW: 8K2 955 119 HW: 8T2 955 119 Labels: 1KX-955-119.CLB Component: WWS 040708 H05 0060 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Coding: 025028 Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G Component: E1 - LDS H07 0070 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 B HW: 8K0 959 655 B Component: AirbagVW-AU10 H26 0410 Serial number: 0038JD173G0R Coding: 30363434363030303030554A3052384B3053 Shop #: WSC 06325 000 00000 ASAM Dataset: EV_AirbaECUVWAUDI010 A02007 ROD: EV_AirbaECUVWAUDI010_AU48.rod VCID: 3C710AB0B74456DE62-8068 Crash sensor for side airbag; driver side: Serial number: 6334MSME2A637838K Crash sensor for side airbag; front passenger side: Serial number: 6344MSME3B314F2CP Crash sensor for side airbag; rear; driver side: Serial number: 6352QSME7D702129I Crash sensor for side airbag; rear; passenger side: Serial number: 6362QSME7D703277O Crash sensor for front airbag; driver side: Serial number: 63732SME7D282F67G Crash sensor for front airbag; front passenger side: Serial number: 63832SME6C303705- No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H12 0013 Revision: -------- Serial number: 90304HG2000EO Coding: 000012 Shop #: WSC 06325 000 00000 VCID: 3D7707B4A45E5FD655-8068 Component: E221 - MFL H02 0003 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8K0 920 980 B HW: 8K0 920 980 B Component: KOMBIINSTR. H16 0221 Revision: 00200000 Serial number: 99563P478 Coding: 2F04080002002600010000 Shop #: WSC 06325 000 00000 VCID: 316F2B846806ABB6C1-8064 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8T0 907 468 H HW: 8T0 907 468 H Component: GW-BEM 5CAN H06 0091 Revision: GB102039 Serial number: 3900G0862981AD Coding: 000303 Shop #: WSC 06325 000 00000 VCID: 46856858F1881C0E04-8012 Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B Component: J367-BDM H04 0150 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb Part No SW: 8K0 959 793 C HW: 8K0 959 793 A Component: TSG FA H10 0170 Revision: Serial number: 0000007364412 Coding: 011002204001410001 Shop #: WSC 06325 000 00000 VCID: 40897E40D3AC323E3E-8014 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 C HW: 8K0 907 064 C Component: BCM2 1.1 H70 0134 Revision: 00002001 Serial number: 0112712488 Coding: 011B062200390440002001 Shop #: WSC 06342 000 00000 VCID: 30692E80630CA2BECE-8064 Subsystem 1 - Part No: 8K0 951 177 Component: DWA-Sensor H02 0040 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H03 1301 3 Faults Found: 02616 - Fuel Tank Cap; Unlock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 52 Reset counter: 16 Mileage: 75064 km Time Indication: 0 Date: 2014.06.13 Time: 23:27:48 02615 - Fuel Tank Cap; Lock 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 2 Fault Frequency: 94 Reset counter: 163 Mileage: 76991 km Time Indication: 0 Date: 2014.07.12 Time: 20:57:27 03123 - Terminal 30 - 2 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 2 Fault Frequency: 1 Reset counter: 247 Mileage: 94899 km Time Indication: 0 Date: 2008.04.06 Time: 08:59:20 ------------------------------------------------------------------------------- Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb Part No SW: 8T0 035 223 AB HW: 8T0 035 223 Component: DSP STD H07 0220 Revision: S1900000 Coding: 0203010102 Shop #: WSC 06325 000 00000 VCID: 6ED5F0F8B9B8F44E9C-803A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8K0 959 792 C HW: 8K0 959 792 A Component: TSG BF H10 0170 Revision: Serial number: 0000007388975 Coding: 011002204001410001 Shop #: WSC 06325 000 00000 VCID: 3F8B7DBCAE524DC647-806A No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 E HW: 8K0 907 801 E Component: EPB Audi B8 H05 0060 Revision: 00000003 Serial number: 00000000163780 Shop #: WSC 00000 000 00000 VCID: 316F2B846806ABB6C1-8064 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 8K0-907-357.clb Part No: 8K0 907 357 B Component: Dynamische LWR H01 0030 Revision: 00000001 Serial number: Coding: 0000004 Shop #: WSC 06324 000 00000 VCID: 3461229057149E9EAA-8060 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb Part No SW: 8T2 035 186 C HW: 8T2 035 186 C Component: Concert3 H02 0210 Revision: 00000004 Serial number: AUZ5Z6H1085151 Coding: 0502008201018D000359070000 Shop #: WSC 06325 000 00000 VCID: 387916A08B7C7AFE86-806C Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A Component: Display 1 Fault Found: 03138 - Input AUX IN 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 131 Mileage: 94296 km Time Indication: 0 Date: 2008.03.04 Time: 01:06:18 ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb Part No SW: 8K0 959 795 A HW: 8K0 959 795 A Component: TSG HL H06 0170 Revision: Serial number: 0000100094522 Coding: 010002204001210001 Shop #: WSC 06325 000 00000 VCID: 40897E40D3AC323E3E-8014 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb Part No SW: 8K0 959 794 A HW: 8K0 959 795 A Component: TSG HR H06 0170 Revision: Serial number: 0000100105954 Coding: 010002204001210001 Shop #: WSC 06325 000 00000 VCID: 3F8B7DBCAE524DC647-806A No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 8P0-862-335.lbl Part No SW: 8T0 862 335 A HW: 8T0 862 335 A Component: FSE_256x BT H33 0520 Revision: 00000000 Serial number: 00000005013400 Coding: 0010320 Shop #: WSC 06325 000 00000 VCID: 387916A04B7C7AFE86-806C No fault code found. End-------------------------(Elapsed Time: 02:48)-------------------------- |
