New! ECS B9 S4 Front Mount Intercooler Upgrade
Improve the power in your B9 S4 with the new ECS Luft-Technik Intercooler!
Click HERE for your ECS B9 S4 Intercooler Upgrade
The ECS Luft-Technik Intercooler provides cooler charge air and more power to the boosted S4.
The upgraded power and updated looks add a new feel to your favorite Audi easily and are designed to fit perfectly for a quality finish.
Reduced intake temperatures and air turbulence
Increased air flow capacity
Up to 30% improved intercooler efficiency
Reduced intake temps by as much as 41*F during dyno runs
Pressure drop reduced by 47%
Cast aluminum intercooler end tanks
Bar and plate design intercooler core
Includes all stainless steel t-bolt clamps and hardware
Easy and direct replacement upgraded intercooler
ECS Tuning's Luft-Technik Intercooler features an aluminum bar and plate core with cast aluminum end tanks, finished in a silver powder coat with the embossed ECS Tuning logo.
The core is not only thicker (3.5" compared to OEM at 3") but it offers a 65.5% increase in frontal area compared to stock intercooler.
Increasing the surface area by using a larger more efficient core design and providing a smoother air path, we were able to lower temps by 41 degrees while increasing the intercoolers efficiency by 30 percent!
The temperature and efficiency data shows that there is a significant reduction in air temperature leaving the intercooler, which will lead to power gains in high stress and high temperature conditions while reducing the strain on the engine.
Click HERE for your ECS Audi B9 S4 Luft-Technik Front Mount Intercooler Upgrade
ECS Tuning
B9 Models
01-13-2017 05:07 PM
Andrew/AWE
09-17-2012 12:57 PM
scottyp33
01-29-2012 10:36 PM
