AudiForums.com
-   Classic Audi (https://www.audiforums.com/forum/classic-audi-19/)
-   -   1990 200Q/T trouble starting (https://www.audiforums.com/forum/classic-audi-19/1990-200q-t-trouble-starting-137529/)
jddrag200 Aug 25, 2009 09:14 AM
Now that it's summer I can get my car started whenever I need to. However, it still requires at least 5-20 seconds of cranking and pumping the gas pedal.
My real problem is when the weather gets cold. Last winter I killed my battery from having to crank the starter so much. Sometimes it would take 20 minutes to get her started, sometimes it wouldnt start at all.
I know the problem is something with the fuel delivery, but what exactly? I hope its not the fuel pump because I know thats expensive (can it be rebuilt?) I don't know know how to check if its the fuel pressure regulator without buying fancy gauges. I imagine its probably leaky injectors. If so, how hard is it to replace these? If I do that is there anything else I should try to fix while Im in there?
Thanks for the help!
salleuxe Sep 11, 2009 08:17 AM
Is it petrol engine?
NH_USA Sep 11, 2009 01:11 PM
I would look at the temp sensor that tells the ECM to make the fuel mixture richer when it is cold.
jddrag200 Sep 15, 2009 07:17 AM
yes regular gasoline engine, where is the temp sensor located?
