89 Audi 90
Old Jun 24, 2007 | 08:05 PM
sdiegidio's Avatar
Default 89 Audi 90
Thanks to all that have helped me so far. I have literally brought this car back from the dead. It's running pretty good just need a few new sensors and a little tweaking.
I seem to have a vacuum loss. Upon anything other than light acceleration I will lose vacuum in heater door causing a/c to blow warm for a min or so. Once the vehicle speed is steady then I get the cold air back.
Problem 2 is. Can the window regulator be adjusted. I have replaced the dricer's door one but the rubber shielding at the top of the regulator that goes into the indent in the door catches the window when it goes down and causes the window to drag. Whem the window is up the cable is relaxed and fits in that groove easily thus making the window go up easily
The final problem I am having and I have checked all the fuses is.. the tach does not work neither does the digital readout in the tach.. The fuel consumption computer in the center of the dash works fine. The speedometer works fine but the odometer and trip meter do no. The temp guage on the left side by the tach does not work either. Anyone have any insight to this. Any help would be appreciated..
Thanks
Steve
Old Jun 24, 2007 | 11:40 PM
InExile's Avatar
Default RE: 89 Audi 90
youre guages might need some resoldering of some connections .... and try a new tenp sensor .... as fot the window i didn't really understand
