Fuel Pump Relay
Old Apr 8, 2007 | 02:11 PM
sdiegidio's Avatar
Default Fuel Pump Relay
Does anyone know where the fuel pump relay is for my 89 Audi 90 5 cyl.. I don't have a book and have no idea where it is.
Old Apr 8, 2007 | 02:25 PM
techbod's Avatar
Default RE: Fuel Pump Relay
looking at the engine from the front the fuses and relays are just below the windshield to the left side and are marked up on the cover to what they are for
Old Apr 8, 2007 | 04:18 PM
sdiegidio's Avatar
Thanks for the reply but the only thing I can see there is the fuse. There is nothing marked fuel pump relay. What I am trying to do is check the fuel flow from the injectors and need the pump to run continuously. I made up a wire with a switch and two ends to jump the relay to check the flow and also to figure out why the cylinders are flooding.
Old Apr 8, 2007 | 04:27 PM
techbod's Avatar
interesting? so the pump dosnt switch off and causes flooding?, can you hear the fuel pump cycle and shut off? if yes then its the airintake system so check the clamps on the rubber pipe from the filter to the throttle body ( any splits will cause that ) also check the fuel regulator
iastudilloi
Sep 27, 2018 04:41 AM
jsethwerner225
Nov 14, 2014 01:55 PM
elye1231
Jun 20, 2011 08:56 PM
driftking8732
Jan 25, 2009 11:47 AM
rnbguy
Jun 29, 2005 11:07 AM
