Fuel Pump Relay
Thanks for the reply but the only thing I can see there is the fuse. There is nothing marked fuel pump relay. What I am trying to do is check the fuel flow from the injectors and need the pump to run continuously. I made up a wire with a switch and two ends to jump the relay to check the flow and also to figure out why the cylinders are flooding.
interesting? so the pump dosnt switch off and causes flooding?, can you hear the fuel pump cycle and shut off? if yes then its the airintake system so check the clamps on the rubber pipe from the filter to the throttle body ( any splits will cause that ) also check the fuel regulator
jsethwerner225
Nov 14, 2014 01:55 PM
