Resetting the ECM...
Old Jul 9, 2007 | 12:10 PM
kibs45's Avatar
Default Resetting the ECM...
Is there a special procedure or is it just the standard disconnect the battery, and let sit? As was in a previous post I am having problems with the car idling. I have replaced all the vacuum lines, cleaned the throttle body and IACV, re-clamped everything, new o-ring for dipstick tube. While this is a significant improvement in smoothness and overall running the car still will not come to a stop light and idle. If you start the car warm it will idle at about 600 rpm but the second you hit the gas and let go it will stall. If the IACV is unplugged the car is very smooth and will idle between 800-1200 rpm, never stalling. When I redid the vacuum lines and etc the engine vacuum rose from about 12 to 17 which does not waver at idle which should mean the vacuum system is tight. Any chance by fixing a major vacuum leak the ecm is now over fueling the engine at idle? Or should I just replace the valve and hope?
Thanks
1990 100Q
Old Jul 10, 2007 | 11:07 PM
InExile's Avatar
Default RE: Resetting the ECM...
try cleaning the valve with carb ceaner 3-4 times
Old Jul 14, 2007 | 05:08 PM
kibs45's Avatar
UPDATE: The ECM reset helped, and the car ran for a couple of days fairly well never stalling, but a couple of days later its up to the same tricks. I think the valve is dead/dying because I can not find anything else it could be. The engine idles so smooth as long the valve is disconnected.
Old Jul 14, 2007 | 10:18 PM
InExile's Avatar
the ISV gets a singnal from a temp swithc ... check that also
Old Jul 15, 2007 | 05:16 PM
kibs45's Avatar
Do you know which terminals on the switch to check and what the proper resistance would be?
Old Jul 16, 2007 | 11:09 PM
InExile's Avatar
ther eis a bunch of info here www.sjmautotechnik.com
Old Jul 18, 2007 | 09:03 PM
kibs45's Avatar
Switches all check appropriately. Idle switch properly triggers signal to the IACV, IACV has current running through it. Will replace IACV and update..
KpF2007
Aug 21, 2009 06:11 PM
SVT21
Sep 16, 2008 07:59 PM
AudiCross
May 9, 2007 09:08 PM
Flippa_s4
Sep 14, 2006 10:50 AM
smythe
Jun 3, 2005 09:12 AM
