2.7 trouble
Where do I start?
last year it started when it got cold out. I have a 2003 allroad quattro 2.7 when outside temp was cold it wouldn't start or crank. if I worked the key it would start. so here it is again getting cold weather. the engine cranks strong, but won't start. epc light is on so I changed the crank sensor. still won't start. I checked all fuses by drivers door. I then checked fuse under hood. There's a 40 amp max fuse in with the ecm. It was popped. so I replaced and still nothing. also with car in on position and checked harness at crank sensor and didn't get 12v. On any of the 3 wires. so now where do I go? I would appreciate any info thanks. |
i think it come from fuses or relay
