2.7T - data log numbers
I had my 2.7T custom tuned (aggressive tune, 93 oct, stock configuratoin; no data logs) and later removed the pre cat and main cat (same tune). The car felt VERY strong, and logged data confirmed:
Max MAF: 250.5 g/s at 6400 rpm Max Torque: 458.6 Nm at 3000 rpm Max HP: 303.9 HP at 6480 rpm Max Boost: 18.1 psi at 3000 rpm With the cats removed, we retuned the car yesterday, but did NOT manage to get any improvements: Max MAF: 256.8 g/s at 5760 rpm Max Torque: 438.1 Nm at 3200 rpm Max HP: 296.3 HP at 6920 rpm Max Boost: 20.2 psi at 3680 rpm The 'butt meter' confirms. Maybe a little more lively above 4k rpm, but less 'torque hammer' around 3k. What are the numbers out there for the 2.7T (VAGcom logs)? Giac, APR, etc for Stage 2 (? gutted pre cat and eliminated main cat, rest stock)? Why are we not seeing improvements that I expected from the surely reduced backpressure and increased exhaust flow? What is the next bottleneck that I an tackle without spending much? Larger turbos have to wait until year end |
Max MAF: 277.6 g/s at 5603 rpm
Max Torque: 458.3 Nm at 3200 rpm Max HP: 320.8 HP at 6900 rpm Max Boost: 18.1 psi at 3100 rpm Tuned by MTM, pre cat is out, running on 98 oct everythingelse stock. |
Originally Posted by T67
(Post 1331224)
Max Torque: 458.3 Nm at 3200 rpm Max HP: 320.8 HP at 6900 rpm Max Boost: 18.1 psi at 3100 rpm Tuned by MTM, pre cat is out, running on 98 oct everythingelse stock. LOVE your torque number (already like mine a lot). |
coll dude
good to see these..............its......its really cool |
Necro bumping this thread ....where are you guys getting these numbers from dyno?
Originally Posted by ratherb1
(Post 1401866)
Vagcom, ECUx, nefmoto logger, etc. They are all in your ECU. Great way to check out the effects of those 'feel good mods' (like "really hot air intake", K&N filter, "Darin Intake mod". But also a must for fine tuning custom tunes (your tuner will tell you what and how to log). |
Yeah I just logged my car for the first time a couple days ago.... Results where not so good
Post results!
the more logs we have the better. Particularly MAF, IAT, (Torque if you have). |
Where should I post them in the main forum or right here?
