2001 a6 2.8l no power to the fuel pump fuse
I bought this 2001 A6 with broken timing belt and bent valves and who knows what else yet. Have fixed the belt and valves and car wont start. I have no power to the fuel pump fuse and a few others ibncluding some labeled engine control. Also the coil has no power. I jumpered some things and the pump works and the coil has power to it with key on and the trigger wires spark in start position. replaced the fuel pump relay and the ignition switch. where does the power route between the ignition switch and the fuel pump fuse and some other fuses
