A4 B5 '01 multiple sensor failure
So I'm driving home from work and five minutes into the drive I come to a stop... 1st and second pull flawlessly, then a pop! And now backfires on every shift along with a top fuel dragsters idle... I checked engine status with torque and noticed I wasn't getting readings from multiple sensors.. no vacuum or boost, no afr metered, both o2 sensors flat.. no fuel trim...
Here are the dtc: P0444: Evaporative Emission Control System Purge Control Valve Circuit Open P0037: HO2S Heater Control Circuit Low (Bank 1 Sensor 2) P0418: Unknown code - More information may be available on the web P0412: Secondary Air Injection System Switching Valve "A" Circuit P1289: [BMW] Switching Solenoid for Air Assisted Injection Valves Bank 2 Control Circuit Signal High [Ford] Cylinder Head Temperature Sensor Signal Greater Than Self-Test Range [Seat/Audi/Volkswagen] Turbocharger bypass valve short to ground P1473: [BMW] Diagnostic Module Tank leakage (DM-TL) Pump Current Plausibility [Ford] Fan Secondary High with Fans Off [Mitsubishi] DPF differential PRS.sensor high [Seat/Audi/Volkswagen] EVAP Emission Contr.LDP Circ Open Circ. P0102: Mass or Volume Air Flow Circuit Low Input P0031: HO2S Heater Control Circuit Low (Bank 1 Sensor 1) P0136: O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) If anyone has any ideas::: :) help would be greatly appreciated! |
