A4 fuel pump overhauled, now engine is giving..
Hi,
I had my A4 2.5tdi t reg fuel injection pump pack in on me. i got it overhauled and when i picked it up from the garage i found the engine was a hell of alot louder than when it went in. It sounded more like a tracter.. proper diesel sound.. This is not a good sound in my opinion, as the engine was alot more smother before the pump packed in. I took the car back to them , but they insisted that the engine and timing was fine and the pump was functioning fine. I am still convinced that somthing is not right. can anyone help me with this.
Maybe the turbo's on the way out.. i haven't got a clue.. any help much appreciated.
Thanks
Thanks
I am not sure how much play the flex pipe should have on a vehicle, seeing how I have never messed with one, but mine has a lot. If that is not the problem, it would have to be a gasket around the converter or the converter itself. I just crawled under it for a second as I didn't have much time. If anyone else knows, the help would be appreciated. Good luck.
Ok i will check it out, The thing is once the car warms up the noise goes and runs sweet.. so i guess it could be somthing thats loose. The engine just sounds so loud when starting it from cold..
I'll keep u posted if i get to the bottom of it.
Thanks
Thanks
jsethwerner225
11-14-2014 01:55 PM
TheDood.
06-14-2014 01:10 AM
M3Armand
04-27-2012 12:45 PM
