Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Audi A6 Oil Sensor Indicator
Old Jul 18, 2011 | 02:39 PM
devinea's Avatar
Default Audi A6 Oil Sensor Indicator
Hey guys
2006 Audi A6 2.0TDI Avant Manual
I keep getting the oil light coming on when the dipstick indicates that the oil level is bang in the middle. If I top it up a little bit the noise goes away for about a month and then returns each time I start the friggin car.
I had issues with my old Golf GT TDI too with the same engine, except that problem was I filled the oil up to max and as a result blew a gasket on the turbo - so I kind of do not want a repeat of that particular repair!
Is this common? Should I just shut up and top up?
Old Jul 25, 2011 | 03:59 AM
demscord's Avatar
Oil pressure levels must be constantly monitored to ensure that your car's engine is well lubricated. With the help of the oil pressure sensor connected to the meter, you can easily monitor any changes in the pressure of its oil.
Old Jul 27, 2011 | 01:37 AM
rakhi's Avatar
The oil sensor warning is apparently indicating that the control module has lost contact with the sensor...no signal, good or bad.
It may not be possible to fake a low oil warning signal, since it's a thermal oil level switch (and if control unit has lost touch with the sensor?).
Old Sep 8, 2011 | 03:59 AM
cynthialin69's Avatar
Basically such problem indicates there are some oil pressure problem and also could be problem on oil service pipe,car engine.Oil sensor indicator helps us to check Oil level and the the corresponding pressure.
Old Oct 17, 2011 | 01:06 PM
devinea's Avatar
Default Bit late... but
Turned out my dipstick was broken - despite looking fine. At a recent EU Kontroll they put 8dl of oil in. Cri. Key. The sensor was fine, it was the manual device that was broken!
Old Oct 26, 2011 | 03:08 AM
terryalice's Avatar
i recently heard about the performance chips and they will work on the engine tell me howz that possible as both are differed by there way of manufacturing
KL2006
Dec 5, 2013 10:54 AM
drft1
Aug 29, 2010 01:36 PM
eugenej
Feb 10, 2009 06:09 PM
Nas
May 5, 2008 11:44 PM
az
Jan 9, 2006 08:36 AM
