In dash display problems?
So after reading the owners manual, I discovered the volcano in the dash meant I was low on washer fluid. I filled it up but the warning indicator failed to go off. I also just spent about an hour in the frigid cold checking my brake light bulbs because I also have that warning flashing at me when I drive. Nothing wrong with the bulbs. Other warnings I am experienceing are defective bulb (none found) and brake pads (possible).
Do I have to somehow manually reset the warning indicators in the dash? I read through the manual and didn't find anything.
thanks for the help...and be gentle on the noob, please.
how cold is it where you are? it could be possible that the fluids aren't getting to certain places because it's so cold... try warming the car up and see if it doesn't go away.
you could also hit the button that does a check on the washer fluid, oil, battery, etc. and seeif it'll magically reset itself.
How cold is it where you are?I guess it could be possible that some parts of the car are frozen and the fluids aren't getting there. Try warming up your car to see if it goes away.
You could also try clicking the button on your dash that checks your oil, washer fluid level, battery, etc. and see if it magically fixes itself.
When the Pixels in Message Center is working wrong, This is a major problem in the TT's, If I have this problem should I fix it right away or leave it like that and the car will not give me far more electrical problems. Did any body knows how much or how to fix this problem? Thanks
