is this an ecu problem?.
ok i have a 96 a4 2.6 quattro , and was fine on the evening when i parked it up but in the morning wont start.
on closer inspection it seem to be pumping loads of fuel in , when i try to turn it over , then causing it to lock as the bores fill with fuel . i have taken all the plugs out and turned it over , how pretty as it fires fuel all over . i changed the air filter the day before , and maybe i could of knocked something ? no idea , and when we tryed to plug diagnostic thing in , it wont read the ecu. any ideas ????????? thanks |
ok found the problem , so were can i buy an intake for the throttle body ?.
is it is the little flappy thing that is not working properly . thanks |
