Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Engine Check Light On - P1128 and P1130
Old Sep 15, 2007 | 04:43 PM
AudiLover75's Avatar
Default Engine Check Light On - P1128 and P1130
Hi All,
I bought my first Audi, its a 2000 4.2 A6. After I had driven the car a 1000 miles the check Engine Light turned on. I got it diagnosed and found that the the Error Codes are :
P1128 Heated Oxygen Sensor Signals reversed.
P1130 Lack of Upstream Heated Oxygen Sensor Switch - Adaptive Fuel Limit - Bank No. 1
My question is what is the cause of these codes and how can I fix them. Also is this something which requires immediate attention? And any rought estimate as to how much it will cost to fix these?
Any help will be appritiated.
-Thanks
Old Nov 5, 2007 | 04:07 PM
betes's Avatar
Default RE: Engine Check Light On - P1128 and P1130
Hey its your o2 sensors so you need to get them replaced and the second one is there is a block in the exhaust for some reason so get the new o2 sensor in there and see how that turns out good luck
Old Apr 10, 2011 | 05:01 PM
mmdambro's Avatar
any updates on this? I had this come up as well as cylinder misfires:
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
17538 - Fuel Trim; Bank 2 (Mult): System too Lean
P1130 - 35-00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16685 - Cylinder 1: Misfire Detected
P0301 - 35-00 - -
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 - -
16686 - Cylinder 2: Misfire Detected
P0302 - 35-00 - -
Old Apr 10, 2011 | 05:25 PM
mmdambro's Avatar
P1128 - 35-00 - -
P1130 - 35-00 - -
P0300 - 35-00 - -
P0301 - 35-00 - -
P0303 - 35-00 - -
P0302 - 35-00 - -
AUDIA642
Nov 8, 2012 06:38 PM
Srgarrett21
Dec 16, 2011 12:57 PM
parlayin
Feb 10, 2010 12:33 PM
blanthony
Mar 25, 2006 01:18 PM
