Hack For Obd2 Sensor
my 2002 audi a4 fail massachusetts emmisions for two bad catalytic converters. i tried twice to reset the light, but it came back on after about fifty miles which isnt long enough to retest it. does anyone know if there is a way to hack the obd2 sensor to my emmisions. i cant afford to fix it right now and i really need the car. PLEASE HELP.....
That is used to move the 02 sensor out of the flow when using a Test pipe. Basically it tends to help lower the readings on that 2nd 02 sensor since there is no longer a cat. You can try it but it might only work if your post cat 02 readings are too high causing the CEL to come on, if the readings are too high or your 02 isn't working at all then its not going to do crap.
boosted98a4
05-25-2011 02:37 PM
