Help! I got a ton of car problems
Address 01: Engine
Controller: 4D0 907 551 AH Component: 2.8L V6/5V MOTR HS D01 8 Faults Found: 18010 17967 17973 16684 16690 18014 16689 16686 |
RE: Help! I got a ton of car problems
18010 ECM supply voltage from battery
17967 throttle control basic setting malfunction 17973 throttle control unit lower stop not reached 16684 random misfire 16690 cylinder 6 misfire 18014 rough road signal circuit malfunction 16689 cylinder 5 misfire 16686 cylinder 2 misfire did you disconnect the battery while doing a test or did the engine stall during the test?? |
The battery has never been disconnected during a test. Nor has the car ever stalled during a test. I also want to mention that the battery has never been disconnected while the engine is on.
| All times are GMT -4. The time now is 04:03 AM. |
