need help! - 2006 a4 2.0t engine light codes 12555, p310b, 00768, p0300, 00771, p0303
Hi guys,
i need some help on my 2006 audi a4 2.0t, my engine light came on so i took it to aamco and the gave me the readout of the OBD II Code Reader. it read: 12555 - low preasure fuel regulation, fuel preasure outside spec p310b - no signal no communication 00768 - random / multiple cyl misfire detected p0300 - upper limit reached int. 00771 - cyl #3 misfire detected p0303 - upper limit reached int. please help. i hope this isnt going to cost to much to fix. Let me know if you guy need any more info. |
I'm running a fuel injector cleaner hoping it's just a clogged fuel injector. As a side note I only feel the jerks from power loss when I punch the throttle, driving it normally (1k to 3k rpm) I feel no problems. Any input is much appreciated. Thank you.
Sounds like the high pressure fuel pump issue these are famous for. How many miles on that car? If lees than 120,000, take it to Audi for diagnosis. If it is the high pressure fuel pump cam follower, they should cover it.
Originally Posted by Audi Dan
(Post 1466605)
The car has 143k miles on it. I don't think audi will cover it. |
Found the problem. took it to several mechanics and they were telling me it could be the fuel pump, or the fuel pressure regulator, or the ignitions coils. But all I did was started with the cheapest parts first like the spark plugs. Changed them to copper core plug like suggested in other post. Now the car runs stronger than ever.
Hopefully this helps someone out there. Shahbaz Www.techprossd.com |
Originally Posted by Techpros
(Post 1467622)
