Please help! Audi a4 2.0t trouble
I recently aquired an audi a4 2.0t with 120,000 miles. I was told it was misfiring and just needed a camshaft position sensor. Check engine light and EPC light are on. I ran a scan and have these error codes:
p2014 intake manifold runner sensor p0190 fuel rail pressure sensor p0118 engine coolant temp sensor p0113 intake air temp sensor p0343 cps a circuit high input b1 I did just put a new camshaft position sensor, no change. I read a forum where a guy had same error codes and it was a bad ground from the ECU. Not sure if ive checked all possible grounds. Any direction or advice would be much appreciated. Thank You! |
