$10,000 Service Estimate from Dealer? or should I try my luck somewhere else? [2001 A
I received this service estimate for my 2001 Audi A4 at a dealership after a check engine light went on and I needed a new key programmed.
What do you think? Additional items noticed during inspection:
Plus original estimate of $398.45 (for oil change, check engine light diagnosis, key programming, and key battery) Should I drop the coin? Take it to different place? Find a new car? My current plan is to call around tomorrow for some more estimates. Any ideas, experience, wisdom to share? :confused: |
You should own a code reader.
U281 VAG OBD2 OBDII ABS SRS Auto Scanner Code Reader Diagnostic Tool VW Audi | eBay Find an independent shop. APR Dealer and Importer Locator Tool GIAC|Dealers |
You're getting raked over the coals on repairs that exceed the value of the car. Order a pollen filter and a coolant tank from RockAuto for probably $40 total, take 10 minutes, and replace them yourself. Most of the rest is well within the abilities of the average DIYer too. In any event, their prices are practically a felony. Go elsewhere.
I agree with the other members. That sort of coin to put down isn't a worthy investment. Find a good independent mechanic for a 2nd opinion. Just an FYI as an example, I paid $120.00 each for CV boots for my '03 A6 4.2..keep doing the math with the rest of the items and you can see you're paying a massive markup to the dealership.
Where are you located? Dealer is trying to rape you!
