2006 A3 2.0TFSI Please help Missfire at idle.
Old Jul 28, 2022 | 01:46 PM
Kurtgobemouche's Avatar
Default 2006 A3 2.0TFSI Please help Missfire at idle.
Hi all, I've recently purchased an Audi A3 2.0TFSI and have noticed a missfire issue only at idle.
Reading the codes i had a carbon canister fault "reverse flow". checked this and carbon canister working properly so cleared this code. Today i also changed the Purge valve incase this was causing the problem but cylinder 3 is still missing.
What ive done so far:
- New NGK spark plugs
- New ignition coil for cylinder 3
- New hengst fuel filter
- Running fuel additives (wynns xtreme petrol )
- New purge valve.
- Checked the pcv valve gasket & hoses but no issue found.
- Sprayed round intake manifold etc with ether to try and identify any air leaks but none found.
Any suggestions would be helpful. I'm sure it can't be head gasket as under load the engine runs very sweet.
Im thinking about changing injectors next.
Thanks in advance.
jharris99
Mar 11, 2014 11:58 PM
grantllete
Sep 4, 2011 10:11 AM
cbg
Mar 1, 2008 12:03 PM
dazA6
Dec 25, 2006 06:17 PM
baddum
Jan 5, 2005 08:20 PM
