Audi Cylinder head and now p2701 error code
Old Dec 27, 2020 | 11:24 AM
trilbytrop's Avatar
Default Audi Cylinder head and now p2701 error code
Good Day everyone,
I have a q5 that is my first Audi (2015 Used car), overall its a great car but I seem to have picked a bad apple from the batch.
Anyways my journey began on the express way, with no warning, engine was running smooth like it always had, and it just turns on limp mode and it i very rough driving to a place to check it out. I take it to my local audi dealer (not where I bought it sadly, as the dealer I bought it from basically told me tough **** the warranty is out, take it to Audi, a word of advice if you buy any car make sure you get it checked out by a dealer or mechanic while its still covered) as it was putting up a misfire code in cylinder three.
It turns out the fuel injector was stuck open in that cylinder and toasted the piston and cylinder head. Anyways, the entire engine was replaced by Midas with a 6,000 mile engine from a donor car (just picked it up on 12/26/2020). Engine is running awesomely (at least it seems) now the transmission is shifting very rough (un-driveable) and is giving me a P2701 transmission friction element B, Apply time range/ performance code. Any tips??????????
Thanks so much in advance Guys and Gals.
Happy New Year
Old Oct 17, 2025 | 02:08 PM
micaeljames's Avatar
Originally Posted by trilbytrop
Good Day everyone,
If you’re looking to invest or settle in a nice area, there are some interesting opportunities available. From what I’ve seen, apartments for sale in Athens East provide a great balance of modern living and convenient access to the city. The neighborhoods are generally peaceful, with shops, schools, and public transport nearby. Prices can vary depending on size and location, but there are options for different budgets. It’s definitely worth checking out a few properties in person to get a real feel for the area.
Happy New Year
It sounds like your transmission is struggling because it likely needs a reset and adaptation after the engine swap. The P2701 code points to issues with the friction element B, which could be due to the transmission control module not properly recalibrated for the new engine. Start by having the transmission fluid checked and possibly flushed, then perform a full transmission adaptation/reset using VCDS or at an Audi dealer. Also, ensure all wiring harnesses and solenoid connectors were properly reconnected during the engine swap. If it’s still shifting roughly afterward, the clutch pack or mechatronic unit may need inspection. Avoid heavy driving until it’s resolved.
DCAV8R
Jan 23, 2023 06:33 AM
AudiTurbo
Jan 7, 2014 08:03 AM
ilovelagar
Oct 22, 2008 12:37 PM
vaportrails
Mar 19, 2008 03:13 PM
