Audi TT quattro 225hp 2002 engine rebuild cost
Hello everyone,
Can someone please help providing right directions on what should I do.
My 2002 Audi TT 225hp quattro 2dr Coupe (1.8L 4cyl Turbo 6M) got the timing belt broken, so most of the valves were bent.
I've been doing research and looks like I have 3 options (please correct if I'm wrong)
Rebuild engine:
Intake Exhaust Valves and Guides Set (ebay #item 200545269213) $169.16
Timing belt W/ WATER PUMP TENSIONER (ebay #item 300976728449) $214.95
Mechanics work $???
Total parts cost: $384.11
Replace with used engine:
Used engine 90k miles (ebay #item 141390381734) $1,999.00
Mechanics work $???
Total parts cost: $2,213.95
Replace engine head and timing belt:
Engine head - used (ebay #item 191221081944) $748.64
Mechanics work $???
Total parts cost: $963.56
I keep hearing that replacing the engine is cheaper (). Because of the list of prices of my options I can't understand why buying parts for $384.11 + work is more expensive than a $2k engine + work + timing belt replacement (to avoid same issue).
I call a mechanic shop and they told me $5,200 is the cost for replacing with a 80k used engine. So, it's about 3 thousand dollars for installing an engine ?
Any comments are appreciated. Thanks!
Rebuild engine:
Mechanics work $???
Mechanics work $???
Mechanics work $???
andrewzpsu
01-27-2011 09:47 PM
wheezyrose
04-09-2008 05:24 PM
showurtt
03-13-2007 12:52 AM
