The Baggie Test - How to inspect for above surface bonded contaminants
After washing and drying your car, the next thing you want to do is to inspect the paint for what we call,
Above Surface Bonded Contaminants
These contaminants can be,
The Baggie Test
If you really want to feel what's going on at the surface level of your car's paint or your customer's car's paint, then use "The Baggie Test" when inspecting the paint for above surface bonded contaminants.
Better yet, if you want to share with your customer one of the problems with their car's paint that you're going to correct, let them also do "The Baggie Test" with you. The average car owner doesn't know what detailing clay is, how to use it or the benefits of using detailing clay to clay automotive paint, let alone how to test for above surface bonded contaminants.
Sharing this little tidbit of knowledge with your customer will demonstrate to them that you really know your business and later, after you've finished the job, letting them feel the now smooth and slippery paint will solidify their trust in your expertise. This can help you to retain their business and potentially led to referrals via word-of-mouth advertising.
To do "The Baggie Test", simply use a clean sandwich baggie by placing your hand inside the baggie and then feeling the horizontal surfaces like the hood, roof and trunk lid. The film of plastic acts to intensify the surface texture created by contaminants bonded to the paint making it more dramatic to your sense of touch when you feel the paint through the baggie.
The Baggie Test
You can also inspect the vertical panels and if you detect above surface bonded contaminants on these areas then they should be clayed also. Generally speaking, air-borne contaminants will land and settle on the horizontal surfaces but drift past the vertical panels where they will land on the ground. The main exception to this rule is any air-borne contaminant that is sticky, like Tree Sap Mist or Overspray Paint.
Resources
The 2 primary benefits of using detailing clay to clay paint
Show Car Garage Videos
How detailing clay works and how to use detailing clay to remove above surface bonded contaminants
- Tree Sap Mist
- Industrial Fallout
- Overspray Paint
- Air-borne Dirt and Dust
- Pollution
- Road Grime
The Baggie Test
The Baggie Test
Resources
