Holy frustrated Batman... how do you gents keep your wheels clean???
I've had my 2009 A4 for 2 days now and have driven 130 miles. The wheels get amazingly dirty amazingly quick. Yikes! :eek:
I have the 10 spoke wheels which I will be changing out to a 5 or 6 spoke after market in the coming weeks. Is there any tips for keeping my wheels clean or at least, making them easier to clean? Thanks in advance for the help! :) |
There are good results reported with Armor All wheel protectant. I have a can to try, but I haven't gotten my wheels clean enough to give it a go yet :-). Others claim waxing, either with a regular wax/sealant or one made for wheels, makes the dust easier to remove. Only the AA stuff, however, is reported to prevent the dust from sticking in the first place.
Originally Posted by EPA7
(Post 1382602)
Thank you. :) I will pick up the AA and give it a go this weekend. |
quick and easy wheel cleening
Meguiars Wheel brightner This is from the proffesional series. Stough is strong and needs to be diluted 1:4, however, I went 1:3. Cleaned the inside of the wheels too. Spray on, rinse off. |
Do all yourselves a favor and buy Sonax Full Effect. I have never in my life seen such an effective cleaner. If you don't go a long time between cleanings, all you have to do is spray and hose. Goes on green and turns red as it binds to the sintered iron.
https://farm6.static.flickr.com/5147...84970f01_b.jpg |
I tried Sonax, and it works pretty well, although after a full bottle (4 applications with soaking and agitation) my i30 wheels still had some spots that were only removed with Meguiar's All Wheel and Tire Cleaner. Given that the Meg's is 1/3 the cost of Sonax, I'm sticking with it as my go-to cleaner.
I did try the Armor All Wheel Protectant after using the Meg's and, while not perfect, it works pretty well. I posted pics here: http://forums.audiworld.com/showthread.php?t=2824273 This was after 340 miles. I now have 1600 miles on the wheels, and other than inadvertently removing the AAWP two washes ago, it has worked great. I reapplied it after the last wash, and have driven 700 miles with just minor smudges of brake dust on the face. A HUGE improvement over no coating. The Meg's strips the AAWP, so I still need to find a way to clean the wheels without having to reapply the AAWP. I haven't tried waxing these wheels, but will stick with the AAWP for the time being. |
Interesting - I actually stopped using Meg's Wheel and Tire Cleaner for the Sonax because I found it worked better. What kind of pads do you run, ceramic or metallic?
4 Attachment(s)
Originally Posted by brrman
(Post 1389718)
My car is a brand new A7. Not sure what kind of brake pads it has, but based on the amount of dust generated I'm assuming they're metallic. I haven't actually tried the Sonax on my car, since I ran out using it on the Infiniti, but the Meg's works well on it. Plus I've been washing it every couple weeks at least, so there hasn't been time for the brake dust to really get baked on. I've added some pics of the wheels 300 miles after treatment. Even though the AAWP significantly reduced the brake dust that stuck to the wheels, the stuff that stuck did not come off with a hose (first pic). I'm going to try a good wheel wax on the winter wheels before I put them on followed by the AAWP to see I can't get the best of both worlds. |
Armor All Wheel Protectant after 1250 miles
2 Attachment(s)
Here are a couple photos of my A7 wheels after about 1250 miles. They were washed at 350 miles on the odometer and treated with AAWP. I haven't touched them since. The odometer's currently at about 1600 miles.
Man, the AAWP seems to do the trick.
| All times are GMT -4. The time now is 04:37 AM. |
