Wes_R x R8 (113 pics)
14 Attachment(s)
Hi everybody,
Todays write up is on a Ibis White R8 with the silver side blade, very classy in my opinion. I had seen this R8 before near the area where I had grown up and can actually remember spotting it one night on my way to the Pacquiao vs Clottey fight(I asked the owner later to confirm it was him). Funny how a car you admire on the street just ends up in your drive way... I love it when life works out like that :). Anyway let's get into the write up. Here she is and a quick walk around of the car. Attachment 30720 Attachment 30721 Attachment 30722 Attachment 30723 Attachment 30724 I start with the wheels/engine/exhaust first, reason being things can get messy and you wouldn't want that mess with a clean already washed car. So we start with these areas first. Brake dust covered rim Attachment 30725 Applying Autoglym Custom Wheel Cleaner. Anything non acidic to clean your rim is best and one thing I love about this cleaner is it's ability to pull dirt out of the tire very well and with some agitation you can turn a brown tire back into black which is great for later on when you apply the tire dressing. You wouldn't wax a dirty car would you? But yet a lot of people dress their tires while they are still dirty not realizing brake dust gets on the tire to. Attachment 30726 Agitating the inner barrel with my EZ Brush. Attachment 30727 Cleaning the rim face with a microfibre mitt. Attachment 30728 And cleaning the caliper with my Race Glaze Brush. Attachment 30729 Cleaned up the exhaust as well. Here they are with some Chemical Guys Grime Reaper applied to them. Attachment 30730 Used my mini EZ Brush to clean in between the dual exhaust. Attachment 30731 And a 0000 steel wool pad to clean inside the pipes. Attachment 30732 Here is an after of how the driver's side looks. Attachment 30733 |
13 Attachment(s)
I didn't want to do an all out cleaning on the engine as I believe this is the same V8 from the RS4 and the coils are exposed, so to get them wet would mean problems. Yet I couldn't just leave the engine bay dusty because it is on display and will be looked at. So I used Optimum Power Clean cut 30/70 with water and wiped the engine bay down with a damp microfibre cloth getting clean areas that I could reach. Afterwards I wiped on Meguiars Hyper Dressing cut 20/80 with water for a natural finish.
Here is an after pic of the engine bay. Attachment 30707 Just before the wash I wanted to clean up all the mesh vents & etc. So I took my Race Glaze Brush and the Optimum Power Clean and cleaned up all these areas first. Attachment 30708 http://i300.photobucket.com/albums/n...ommysr8/20.jpg Attachment 30709 http://i300.photobucket.com/albums/n...ommysr8/17.jpg Attachment 30710 After brushing out the vents I foamed down the car with Prep Wash to strip off any silicones that might have been applied to the paint. Doing this would help reveal the true condition of the paint stripping off any filler products that might have been hiding anything. Attachment 30711 Let it dwell for a bit while I prepared to wash the car. Attachment 30712 The two bucket method was used to wash the car. The reason for washing with two buckets is simple one bucket is water the other soap, after every panel you rinse off the dirt from your wash media in the water only bucket before you dip it back in the soap bucket. Doing it this way prevents you from dragging dirt all over your paint causing more swirls on the paint. Some can say that I am going to polish out the swirls any way but I feel it is backwards to induce more while I am washing. http://i300.photobucket.com/albums/n...ommysr8/23.jpg Natural Sea Sponge was my wash media. Attachment 30713 Dried off the car with my waffle weave towels and then brought it in to clay the paint. For those of you not to familiar with what clay does, it basically sheers out contaminants embedded in the paint. This can be raildust, fallout, or even just tiny dirt debris. If you wash your car and run your hands along the paint you will probably find that it is rough. What you are feeling is the surface contaminants. Riccardo Yellow clay was used. I had run out of lube which is usually Meguairs Last Touch cut 50/50 with water but this time it was just straight water. http://i300.photobucket.com/albums/n...ommysr8/25.jpg Paint was fairly contaminated but not terribly. Attachment 30714 Moving along I measured the paint to look out for any low spots or if anything had been repainted. I found the paint to be fairly thick with every panel being 170 microns or more with the average being about 200 microns. I found it funny that a stone chip I noticed still had paint in it instead of exposed metal, just to give you an idea of how thick the paint was as well Audi paint is known to be rock hard so that helps to. Attachment 30715 Attachment 30716 Attachment 30717 I masked up all the non metallic trim to protect them from getting burnt. Attachment 30718 Attachment 30719 |
17 Attachment(s)
Now we begin the surgery.
I was hoping to just 1 step polish the paint but with Audi paint being rock hard I had to 2 step it to correct the swirls and then to jewel the paint to a high gloss. My process for the first step was Meguiars M205 with a Lake Country orange pad on the Makita rotary and here are the results I was getting. Before Attachment 30690 After Attachment 30691 Before Attachment 30692 After Attachment 30693 Before(I don't know what happened here, but it looks like brillio pad work) Attachment 30694 After Attachment 30695 Before Attachment 30696 After Attachment 30697 Before Attachment 30698 After Attachment 30699 Before Attachment 30700 After Attachment 30701 Before Attachment 30702 After Attachment 30703 Before Attachment 30704 After http://i300.photobucket.com/albums/n...ommysr8/41.jpg Before Attachment 30705 After Attachment 30706 |
18 Attachment(s)
Before
Attachment 30672 After Attachment 30673 The tail lights were even swirly so I gave those a polish to. Before Attachment 30674 After(this was after one hit, to correct it better it required a second hit) Attachment 30675 I gave the car a wipe down with ipa alcohol cut 50/50 with water and then jeweled the paint with a grey 3M backing plate, a white Lake Country pad, and Menzerna PO85rd. Here is a shot of me jeweling the paint. Attachment 30676 And the results of my work. Attachment 30677 Attachment 30678 After a couple hours of jeweling the paint and completing the last step I finally unmasked the car. Attachment 30679 http://i300.photobucket.com/albums/n...ommysr8/58.jpg Dusted out the crevices. Attachment 30680 And then gave the paint a 2nd ipa wipe down to clean off the polishing oils. Attachment 30681 Attachment 30682 Here she is cleaned up. No wax yet but still a nice gloss because of the jeweling. Attachment 30683 As well before doing my last steps I double checked the paint with my 3M Sun Gun which omits the same spectrum light as the sun. Attachment 30684 No swirls. Attachment 30685 On to the waxing now to protect the new finish. Wax for the day is Swissvax Concorso. Attachment 30686 Attachment 30687 While the wax was curing I cleaned the windows with my Glass Master Pro and Stoners Invisible Glass. Attachment 30688 Dressed the tires with Blackfire Long Lasting Tyre Gel which was applied then wiped off later for a natural finish. And I applied Poorboys Wheel Sealant to the rims to protect against brake dust and the exhaust as well. Attachment 30689 |
12 Attachment(s)
Poorboys Wheel Sealant on the rims
Attachment 30660 An after pic of the rims and tires. Attachment 30661 And Poorboys Wheel Sealant on the exhaust. Attachment 30662 And an after pic of the exhaust. Attachment 30663 I wiped off the wax and rolled it out to inspect it under the "light of truth". Perfection(not really lol, there were a few deeper scratches but we got close enough) Attachment 30664 Attachment 30665 Attachment 30666 Attachment 30667 Now the after pics and the fruits of my labour. As a quick explanation, I did not adjust the white balance on my camera properly so the pics have a blue tinge to them but to be honest I kind of like it as it makes them look artsy fartsy. Anyway you be the judge. Attachment 30668 Attachment 30669 Attachment 30670 Attachment 30671 |
16 Attachment(s)
Attachment 30644
Attachment 30645 Attachment 30646 Attachment 30647 I really like the gloss in this pic, not bad for a white car huh. Attachment 30648 You can't have the engine exposed like this and not take a pic of it. http://i300.photobucket.com/albums/n...ommysr8/83.jpg Attachment 30649 Attachment 30650 Attachment 30651 Attachment 30652 Attachment 30653 Attachment 30654 Attachment 30655 Attachment 30656 Attachment 30657 I really like the composition in this pic. Attachment 30658 Attachment 30659 |
14 Attachment(s)
I thought the reflection on the hood was crazy, it looks like another dimension in there.
Attachment 30630 A couple of those "cool guy" pics. No dry steering was involved in these shots. http://i300.photobucket.com/albums/n...mmysr8/112.jpg Attachment 30631 Attachment 30632 I like the way the hood looks in this shot. Attachment 30633 Attachment 30634 Attachment 30635 The gloss in this shot looks crazy too. http://i300.photobucket.com/albums/n...mmysr8/102.jpg Attachment 30636 Attachment 30637 Attachment 30638 Attachment 30639 Attachment 30640 Attachment 30641 Attachment 30642 And the money shot. Attachment 30643 I hope you enjoyed reading through and seeing the transformation, as well as picked up a couple things on the proper way of taking care of your car. All comments are welcome and any questions feel free to ask. Cheers, Wes |
I love this show!! I watch it everytime its on tv even if its a re-runn. This tron car is also so cool, how did you get the wheels to light up like that?
Good job, looks very nice. How much would you charge for a detail like that?
Mine dosen't need that extensive of a cleaning, it's just an A4. My wife's BMW needs something like that bad. |
