B5 Front suspension diagram including all torque values
2 Attachment(s)
I made this in anticipation of installing my control arm kit. Hope others find it useful. It's for my B5.5 A4 2.8 Quattro Avant
3 Tower bolts - 48ftlb/55ftlb note* there's a conflict in the bentley re: the tower bolts. The exploded suspension diagram says 55ftlb but the "Mounting bracket, removing and installing" section says 48ftlb Special note for (23) Rubber bushing style link - 30ftlb+90* for upper and lower Ball joint style link - 30ftlb+90* at control arm and 74ftlb at Stab bar I grabbed these from the bentley and it's what I'll use and of course this is only to illustrate how I'm doing it :) Attachment 28901 |
This is great info, thanks man! I vote one of the mods/admins add a link to this in the FAQ sticky.
On its way to the DIY section now.
Upper CA installation angle & torque
2 Attachment(s)
I tried to add this to my exploded suspension and torques post but it was locked...
For stock heights in stead of "setting it where the old ones were" you can use this spec Attachment 28894 |
It shouldn't have locked up but I'll add this to the thread.
One note about this, though I'm not sure how critical it is: the upper CAs have inner bushings which don't pivot when the suspension cycles; the bushings only flex (this is why they have to be set a certain way). It's good you noted that the upper CAs should be oriented in that fashion for "stock heights" because when a car is lowered, the upper CA inner bolts/bushings could be re-oriented to match the new ride height.
Generally it is essential to torque the lower CA mounting bolts only when the suspension is compressed to the new ride height because that will maximize bushing longevity. I doubt that torquing the upper CA inner bushings in that fashion is nearly as critical because those bushings don't take much of a load compared to the lower CA bushings. |
Ok, both the diagram threads are merged and part of the DIY forum. Once again, thank you Savantv for kicking some more ass. Keep this stuff coming anytime you feel like it:D
